ARRIA 10 NOT PROGRAMMING
- 4 years ago
Hi Vivek,
It is ok for INIT_DONE to be high before configuration.
Reason we ask to switch the FPGA to another good FPGA because we need to know if the board is working or not as we suspect the board is having problem. It is better to try this.
Aiman
Hi Vivek,
Looks like the board is the problem. Have you try to program another working FPGA on this current board?
As current FPGA is working fine on another board, can you try another working FPGA on the current board that is having problem?
If it is not working, then it can be the board problem and you need to use another good board.
Aiman
It will be difficult to change the FPGA but will keep this as last option.
One more observation INIT_DONE pin in this board is showing "high" before configuration. Is this correct?
Thanks and Regards
Vivek
