VivekV
4 years agoARRIA 10 NOT PROGRAMMING
Hi
We are using the 10AX027H4F34E3SG Arria10 device in our design and have noticed that the arria 10 device has stopped getting programmed recently.
1) The device gets detected and boundary scan...
- 4 years ago
Hi Vivek,
It is ok for INIT_DONE to be high before configuration.
Reason we ask to switch the FPGA to another good FPGA because we need to know if the board is working or not as we suspect the board is having problem. It is better to try this.
Aiman
VivekV
4 years agohi,
- Since you said the Arria 10 has stop getting programmed recently, do you mean you have successfully program the device before?
- Yes it was working before
- Is there any changes that was made before you get this error(after the successful programming).
- No it suddenly stopped working.
- What is the Quartus version that was used?
- Quartus Prime Pro 20.2.0.50
- Have you try to program the same FPGA on another board? Or program another working FPGA on the same board? Or try to program using another PC? Just to see if both are working fine
- Yes its working on another board, we were able program same file on another board of same.
- Did tried different PC and different USB blaster its same behavior not programming on this board.
- Have you try to used another USB Blaster?
- yes we have tried using different USB Blaster results are same.
Is it possible FPGA has gone bad?
Thanks and regards
Vivek
