VivekV
4 years agoARRIA 10 NOT PROGRAMMING
Hi
We are using the 10AX027H4F34E3SG Arria10 device in our design and have noticed that the arria 10 device has stopped getting programmed recently.
1) The device gets detected and boundary scan...
- 4 years ago
Hi Vivek,
It is ok for INIT_DONE to be high before configuration.
Reason we ask to switch the FPGA to another good FPGA because we need to know if the board is working or not as we suspect the board is having problem. It is better to try this.
Aiman
NurAiman_M_Intel
4 years agoHi,
Thank you for your response.
- Since you said the Arria 10 has stop getting programmed recently, do you mean you have successfully program the device before?
- Is there any changes that was made before you get this error(after the successful programming).
- What is the Quartus version that was used?
- Have you try to program the same FPGA on another board? Or program another working FPGA on the same board? Or try to program using another PC? Just to see if both are working fine
- Have you try to used another USB Blaster?
Aiman
