VivekV
4 years agoARRIA 10 NOT PROGRAMMING
Hi
We are using the 10AX027H4F34E3SG Arria10 device in our design and have noticed that the arria 10 device has stopped getting programmed recently.
1) The device gets detected and boundary scan...
- 4 years ago
Hi Vivek,
It is ok for INIT_DONE to be high before configuration.
Reason we ask to switch the FPGA to another good FPGA because we need to know if the board is working or not as we suspect the board is having problem. It is better to try this.
Aiman
VivekV
4 years agoHi,
We have verified the connections and device, The sof file was programming before, suddenly this error is coming. we are using same sof which was working.
nCE is low and verified all config pins, JTAG pins and voltages. still the problem persists.
Thanks and Regards
Vivek
