VivekV
4 years agoARRIA 10 NOT PROGRAMMING
Hi
We are using the 10AX027H4F34E3SG Arria10 device in our design and have noticed that the arria 10 device has stopped getting programmed recently.
1) The device gets detected and boundary scan...
- 4 years ago
Hi Vivek,
It is ok for INIT_DONE to be high before configuration.
Reason we ask to switch the FPGA to another good FPGA because we need to know if the board is working or not as we suspect the board is having problem. It is better to try this.
Aiman
NurAiman_M_Intel
4 years agoHi,
Please check your connection again and make sure to select the correct device. Kindly refer to below action:
https://www.intel.com/content/www/us/en/support/programmable/articles/000076928.html
Aiman
