8 years agoArria 10 multiplier speed
I'm rather new to practical FPGA design though I have a lot of theoretical background. I'm working with (starting/trying to would be more accurate) the Arria 10 development kit which has Arr...
8 years agoWhile I have your attention:
The exact device I have on my evaluation board is 10AS066N3F40E2SG which I have hard time decoding and relating to the datasheet. 10A = Arria 10 S = ??? 066 = 660 klog elements N = 48 transceivers 3 = transceiver speed 1..5 F = fineline BGA 40 = 40x40mm2 package E = extended temperature range 2 = FPGA fabric speed 1..3 S = standard power G = RoHS6 But when the datasheet talks about speed in connection with multipliers/memory blocks and MHz it uses the title 'performance' in the tables and lists frequencys for variants like –E1S, –I1S, –E2L, –E2S, – E2V, –I2L, – I2S, –I2V, –E3S, –E3V –I3S, –I3V, – A3S So which one I have? cheers Kusti so
