TSchu3
1 year agoArria 10 M20k block usage- More block with less memory bits?
Hello I have a design that fits on the Arria 10 GX dev board with chip 10AX11552F4sI1SG which has 2713 M20K blocks. The total memory bits for this design are 36,171,984, all 2713 blocks are used. ...
KennyT_altera
1 year agoUnderstand that manually adjusting each component is not a scalable long-term solution. A more efficient approach is to explore global settings, macros, or scripting to minimize maintenance overhead. Future versions of Quartus may introduce improved heuristics to address this issue more effectively. However, without a project available for experimentation, testing and refining scripts is currently not feasible. This remains a limitation we can manage for now.
