TSchu3
1 year agoArria 10 M20k block usage- More block with less memory bits?
Hello I have a design that fits on the Arria 10 GX dev board with chip 10AX11552F4sI1SG which has 2713 M20K blocks. The total memory bits for this design are 36,171,984, all 2713 blocks are used. ...
KennyT_altera
1 year agoDoes the above recommendation help?
TSchu3
1 year agoYes, it does help to an extent. I can manipulate Quartus into using different types of memory or logic on a component by component basis. This is very time consuming and not really scalable. Any changes to the design require additional requirements.
It seems to be the best we are going to get at this time, since I am un-able to send the design to you for review.
