Arria 10 M20k block usage- More block with less memory bits?
Ok, so the problem seems to be that the new project targeting the smaller Arria device is not using any MLABS.
The original project on the larger Arria, is using many MLABs.
The settings that I am aware of that cover MLAB usage are
Auto RAM to MLAB Conversion- This is set to ON in both projects
Equivalent RAM and MLAB Paused read capabilities- Set to CARE in both projects
Equivalent RAM and MLAB power up- Set to AUTO in both projects
MLAB add timing contraints for mised port feed through mode setting don't care- set to OFF in both projects
They match which is expected since the new smaller chip project is just an archive of the original (and functional) project but moved to a different (smaller) chip.
What could cause the new project to not use any MLABs? Other settings I'm missing?
Thanks again.
Does anyone have any suggestions? This problem still does not make any sense to me and none of the suggested ideas/issues explain what I am seeing.
