TSchu3
1 year agoArria 10 M20k block usage- More block with less memory bits?
Hello I have a design that fits on the Arria 10 GX dev board with chip 10AX11552F4sI1SG which has 2713 M20K blocks. The total memory bits for this design are 36,171,984, all 2713 blocks are used. ...
TSchu3
1 year agoHi, no I can't send the design it is proprietary.
Can you point me to any Quartus reports or settings that might shed some light on this?
Another point of information. If I further reduce memory usage to 30,466,048 which is a reduction of 2,495,320 it is suddenly able to fit and uses all 2131 M20k blocks. But somehow the design with 32,961,368 bits needs 2845 blocks? That's a difference of 714 M20k blocks or 14,280,000 bits but I only needed 2,295,530 bits.
This is really not adding up for me.
Thanks again.
