Arria 10 M20k block usage- More block with less memory bits?
Are you saying on the original device you used *exactly* the number of M20K blocks available, 2713? That is quite a feat.
As for why it may need more now, it really depends on how you are implementing the RAM. It may not be able to be optimized exactly the same way it was on the original chip.
Showing some code might help.
- TSchu31 year ago
Yes I used exactly 2713 blocks. Its really not that difficult. It did not use all of the bits though.
The RAM is implemented in many many ways, from Fifos to instantiated Block RAM IP.
I am not seeing how the RAM would not be implemented in the same way on the new chip. It is just a smaller version of the same Arria 10. It has fewer M20K blocks, not different memory blocks (M10k for example); its not a different family (Cyclone, Stratix, etc.)
I am failing to see how optimization could cause it to need MORE memory blocks when I significantly reduced the required memory bits.
Thanks- sstrell1 year ago
Without seeing the design and how you've organized all the memory, there's really no way to know what happened.
