Arria 10 Linux Kernel
HI Joshua,
May i have the following item:-
1 What board are your use (Intel dev of Arrow dev, custom board)
2 What design are using (GSRD, ref design)
3 Any hardware modification
4 Software modification(uboot, linux kernel)
5 do you have error log ?
Thank you,
Aliff
- JoshuaWillson2 years ago
Answer: Terasic HAN Pilot Platfrom Arria 10 SoC
Answer: GHRD that Terasic points too in following link https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=216&No=1133&PartNo=4#contents REVF
Answer: Adding in soft IP TSE design, w/ MSGDMA, HPS i2C, and pio for connecting a design w/ SFP modules
Answer:
uboot: v2023.10
linux kernel: Linux version 6.1.38
Answer:
No error log: Could not even get the kernel to boot. But this is where it stops:
Starting kernel ...
Deasserting all peripheral resets
Please note:
For any one with the same problem it came down to the DTB. Im not sure what part exactly from the DTB the kernel did not like but I had different versions of a DTB from example designs and the one that worked was the DTS from a10s_tse_example_design from rocketboards. I was using the DTS from the compiled DTB from terasic that came with the development board and that one was causing issues.
MY assumption is there was some peripheral that the kernel could not talk too (i2C, spi, etc) that was hanging the kernel.
- mabdrahi2 years ago
Contributor
Hi Joshua,
Can you share all your booting log?, it might have information's there.
Thank you,
Aliff
