Arria 10 HPS EMAC with KSZ9131 PHY
Hi Zach,
I'm assuming from your initial post that you are using the HPS EMAC (from Synopsys). Is this correct?
We are running into a very similar problem with our custom Arria 10 SX board and the KSZ9131 PHY. We seem to be able to transmit properly but never receive successfully. We are running our ping tests in U-Boot rather than Linux for now.
Have you had any luck in resolving your problem?
Greg
Hi Greg,
That's correct.
We've been able to work around the problem in Linux by adding the following properties to the PHY device tree node:
eee-broken-100tx; eee-broken-1000t;
These disable advertisement of EEE in the Arria 10's PHY so that even if the link partner advertises EEE, it doesn't get enabled.
Since both the the KSZ9131 PHY and HPS EMAC claim to support EEE, we're still not sure why this is necessary.
I'm not sure if U-Boot has the same (or equivalent) device tree properties to disable EEE.
Zach
