TWatt3
5 years agoArria 10 GX FPGA with PCIe core no coreclkout_hip
I have a board with an Arria 10 GX FPGA on it.
We are using the PCIe core in the FPGA.
Using SignalTap, we are able to see the PCIe refclk toggle at the expected rate (100 MHz).
W...
KhaiChein_Y_Intel
5 years agoHi,
Could you share the signal tap for the below signals? Besides this, could you try running the example design?
serdes_pll_locked
coreclkout_hip
refclk pin
pll_cal_busy
tx_cal_busy
rx_cal_busy
pin_perst
npor
reset_status
pll_locked
rx_is_lockedtoref
rx_is_lockedtodata
ltssmstate[4:0]
lane_act[3:0]
KhaiY
Lilian_61
3 years agoHi KhaiY,
I want to monitor these signals, but I don't know how to connect then on SignalTap.
I didn't find these output of Hard IP.
Are they the internal signals? How can i connect them correctly and quick to SignalTap.
Could you give some instruction on this?
Lilian_61
