TWatt3
5 years agoArria 10 GX FPGA with PCIe core no coreclkout_hip
I have a board with an Arria 10 GX FPGA on it.
We are using the PCIe core in the FPGA.
Using SignalTap, we are able to see the PCIe refclk toggle at the expected rate (100 MHz).
W...
TWatt3
5 years agoHi KhaiY,
I have the CLKUSR pin tied to ground. I checked the "Intel Arria 10 GX, GT and SX Device Family Pin Connection Guidlines" document (pcg-01017.pdf and see that the CLKUSR pin must be connected to a clock for the transceivers to work.
So this is probably the problem?
Todd
TWatt3
Is the only option for the CLKUSR clock to drive the CLKUSR pin from an external oscillator for the transceivers?
Is it possible to assign CLKUSR within the FPGA from a 100 MHz clock and not use the external pin?
Todd
