MehmetFide
3 years agoArria 10 GX: 64 bit atomic access to Avalon Bus through PCIe?
We have an external processor Arm Cortex A53 with Linux 5.4 aarch64 connected to an Altera Arria 10 GX FPGA through a PCIe bus.
On the FPGA side, we have an Avalon bus, all addresses are se...
Wincent_Altera
3 years agoHi,
If you just want to use PCIe IP that interact with memory directly, then pls consider checking out below example design that use (PCIe) only, no DMA
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-a10-pcie-avmm.pdf
- This is the example design that you can generate from PCIe IP directly
- This example design currently connect to on chip RAM but you can replaced with DDR4 if you want
Wei Chuan
