8 years ago
Arria 10 DSP 18×18 Sum of 2 Mode
I am looking at the
Intel® Arria® 10 Native Fixed PointDSP IP Core User Guide
ug-01163
2017.03.13 https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_nfp_dsp.pdf
On page 14, it indicates the equation for the 18x18 Sum of 2 mode is
resulta =[±(ax * ay) + (bx * by)]
Looking at the block diagram in Figure 3, I think it should be:
resulta =[±(ax * (ay ± az)) ± (bx * (by ± bz))]
Is that correct, or is there an error in the block diagram?
Also, what is the significance of white blocks or dotted blocks in the block diagram?
For instance, does the negate function exist in this mode (it is white)?
    Thanks for the clarification.
    Equation in user guide is when preadder is disabled.
    If you enable preadder out equation will be [±(ax * (ay ± az)) ± (bx * (by ± bz))].
    Anand Raj Shankar
