Arye_Nudel's avatar
Arye_Nudel
3 years ago
arria 10 ds-5 not recognize target
we manufacture products that using arria 10, when we get new board we burn it using Jtag. (USB bluster)
at first we burn JIC file for the arria 10 soft processor using Quartos
following with procedure where we open using DS-5 communication with the arria 10 HPS, we run uboot that burns some flash
we got 6 among 100 boards where the JIC burn procedure completes fine
but when we try to start the DS-5 communication link we get the notification that target not recognized, verify if its arria 10.
same setup worked fine for other 94 boards
its done with using same USB Bluster,
what could be the reason, could it be that the Jtag communication receives wrong IDCODE and thus not recognize it as arria 10?
but how the JIC burn via Quartos works fine?
we retried and check everything many times …
P.S. replacing the FPGA component never solved some debug issue for us.
Thanks a lot,
Arye
  • I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions
    • Arye_Nudel's avatar
      Arye_Nudel
      solved, we were missing HPS clock on our boards, somehow it was shorted
