Arria 10 DDR4 issues
- 3 years ago
I found an issue with a clock crossing boundary that should have affected both banks but yet only bank 0 failed.
The design looks good now.
Mike
Hi Mike,
Thank you for submitting your question in Intel Community.
Thank you for providing your issue in details.
So now you have two identical DDR4 memory interface in a design. The Bank 0 has issue but Bank 1 is fine.
Regarding to the issue, do you see any symptom that can cause the failure? Any specific transaction that will fail?
Have you tried to test the Bank 0 alone in a design?
Like making a design with one interface only.
If that possible, can you observe the result?
Can you test the board design with EMIF example design for each interface?
Please let me know if you need help to create the design. Thank you.
Adzim
