11 years agoArria 10 clock problem
Hello, Im implementing a custom design using Arria 10 (10AX115N4F40I3SG). During Place and Route, the following problem related to clock asiignement appears: :confused: Error (179009): Coul...
11 years agoHello,
Thank you for your replies. In fact, as bfkstimchan said the pin AJ5 is a normal clock. I even tried 3 others clock inputs and I still have the same problem. Anyway, since this clock input feeds an internal PLL in my design (Altera normal PLL IP), i replcaed this PLL with Altera IOPLL IP. The problem is solved! I think that the error is related to the placement of the normazl Altera PLL during Plca e and Route phase. Thnak you all for your help. Best regards.
