11 years agoArria 10 clock problem
Hello, Im implementing a custom design using Arria 10 (10AX115N4F40I3SG). During Place and Route, the following problem related to clock asiignement appears: :confused: Error (179009): Coul...
11 years agoAs I understand it, the CML IO standard is for transceiver refclk but not normal clock input. Just wonder if the pin_aj5 that you are using is a transceiver refclk pin?
