Arria 10 cannot access Transceiver ATX PLL reconfiguration interface
- 3 years ago
i found the problem. It is hardware related:
I found it strange that the integrated processor, which takes care of the initial callibration, did not react. If I understand correctly, it is clocked by the 100 MHz user clock (clkusr). I checked the 100 MHz oscillator and well... it does not work. Since we don't use this oscillator for anything else, we didn't notice it earlier.
Thanks for the help, my problem is solved.
Regards, LFrin
i try to access the dynamic reconfiguration interface directly from the Nios V. Is that not possible? Do i have to use an bridge?
I do not find any documentation for this topic (using nios and transceiver reconfiguration interface).
Thanks for the link, i will read the document again, perhaps i missing something.
Regards, LFrin
