Arria 10: Booting U-Boot from SD-Card does not configure FPGA
- 3 years ago
Hi @aikeu,
okay, now im sure: The Intel In-System Sources and Probes IP hinders the FPGA from starting normally after it has been correctly configured by SD-Card. Even the old Quartus-Project works without the ISSP-IP. Now it makes sense why the FPGA starts when a connection to the programmer is established via JTAG or similar.
My workaround will be, that i only use FPGA Firmware without the debugging features (ISSP, SignalTap, ...) on the SD-Card and when i need this debugging features i will start the HPS with the ARMD DS debugger.
Thanks for the help, my problem has been solved.
LFrin
Hi LFrin,
Can try to troubleshoot with the pre-made image by changing the partition content with the ones that you have built?
- dd if=.sfp of=/dev/sdb3 bs=64K //this is to update just the A2 partition with the SPL
- Update fit_spl_fpga.itb and u-boot.img
At the mean time I am trying to consult further regarding your previous observations.
Aik Eu
