Arria 10: Booting U-Boot from SD-Card does not configure FPGA
- 3 years ago
Hi @aikeu,
okay, now im sure: The Intel In-System Sources and Probes IP hinders the FPGA from starting normally after it has been correctly configured by SD-Card. Even the old Quartus-Project works without the ISSP-IP. Now it makes sense why the FPGA starts when a connection to the programmer is established via JTAG or similar.
My workaround will be, that i only use FPGA Firmware without the debugging features (ISSP, SignalTap, ...) on the SD-Card and when i need this debugging features i will start the HPS with the ARMD DS debugger.
Thanks for the help, my problem has been solved.
LFrin
- LFrin3 years ago
Okay, I found something strange. I think that the FPGA is programmed correctly, but does not start.
As soon as I do anything on the JTAG interface after booting my custom U-Boot SD-Card (Quartus-Programmer-Autodetect/ARM-DS-Debugger/Insert external USB-Blaster/...) the FPGA starts running normally.
The board has an on-board USB-Blaster-II, I'm afraid this somehow prevents the FPGA from starting. However, I have no idea why and especially I do not know why the supplied SD-Card-Image works without this problem.
