Arria 10: Booting U-Boot from SD-Card does not configure FPGA
- 3 years ago
Hi @aikeu,
okay, now im sure: The Intel In-System Sources and Probes IP hinders the FPGA from starting normally after it has been correctly configured by SD-Card. Even the old Quartus-Project works without the ISSP-IP. Now it makes sense why the FPGA starts when a connection to the programmer is established via JTAG or similar.
My workaround will be, that i only use FPGA Firmware without the debugging features (ISSP, SignalTap, ...) on the SD-Card and when i need this debugging features i will start the HPS with the ARMD DS debugger.
Thanks for the help, my problem has been solved.
LFrin
Hi @aikeu,
>> You mentioned that you wanto use the new building boot loader flow? The flow will be the same for all Arria10 family devices
I meant that the example project from Terasic was built with Quartus 18.1 and the SOC EDS and I work with 22.3 and U-Boot.
>> I think the pre-made one can work, try to checkout and see.
I will try this and then report back.
