Arria 10: Booting U-Boot from SD-Card does not configure FPGA
- 3 years ago
Hi @aikeu,
okay, now im sure: The Intel In-System Sources and Probes IP hinders the FPGA from starting normally after it has been correctly configured by SD-Card. Even the old Quartus-Project works without the ISSP-IP. Now it makes sense why the FPGA starts when a connection to the programmer is established via JTAG or similar.
My workaround will be, that i only use FPGA Firmware without the debugging features (ISSP, SignalTap, ...) on the SD-Card and when i need this debugging features i will start the HPS with the ARMD DS debugger.
Thanks for the help, my problem has been solved.
LFrin
Hi LFrin,
I think the pre-made one can work, try to checkout and see.
You mentioned that you wanto use the new building boot loader flow? The flow will be the same for all Arria10 family devices
Aik Eu
- LFrin3 years ago
Hi @aikeu,
Unfortunately, the pre-made SD card you mention does not work. U-Boot starts booting but then gets stuck:
Boot Console Arria 10 SOC Intel SoCDK Preebuild SD-Card
