ARRIA 10 Bidir GPIO Synthesis error
Hi ,
I try to instantiate a tri-state buffer using the GPIO IP CORE . Although i assume that i had made all the connection correct the synthesis stage outcomes this error
Error(17044): Illegal connection on I/O input buffer primitive i2c_test|gpio_0|core|i_loop[0].altera_gpio_bit_i|input_buffer.ibuf. Source I/O pin i2c_test|pad_io[0] drives out to destinations other than the specified I/O input buffer primitive. Modify your design so the specified source I/O pin drives only the specified I/O input buffer primitive.
The connections that i had in the top level design are the following
inout wire tri_buff;
i2c_bidir u0 (
.dout (),
.din (),
.oe (),
.pad_io ( tri_buff)
the tri_buff signal does not drive any other destination and i cannot understand why the above error occurs
Thanks in advance
- empissas
I finally found why the synthesis stage had this error.
- sstrell
Strange. Anything unusual about the pin you selected for this in Pin Planner?
- empissas
No, nothing unusual. I assume that the pad_io signal has to be assigned an inout top level pin in order to connect to the pad . Is that right?
- sstrell
I believe so. Does it show as bidirectional in the Pin Planner All Pins list?
Oh, since you can't synthesize, you might not even be able to do that. Hmm.
Is the first stage of synthesis, Analysis & Elaboration, successful if you run it on its own?
