8 years agoArria 10 auto configuration issue with EPCQ-L
Hi experts,
I come across a serious issue on my Arria 10 board, using 10AX016C4. Flash memory is EPCQ-L256 When I wrote program using jic-file with USB Blaster 2, some jic-file, call as "A.jic" here in after, caused auto configuration issue. Once programming and verify have completed successfully, but after power off-on, auto configuration failed. Configuration has not done, and this was mysterious symptom though , JTAG-TDO port has become TDI through port, no clock delay, exact same with TDI. As I cannot use JTAG port, because TDO doesn't run correctly, I erased EPCQ-L by Active Serial port. Then TDO port became Hi-Z correctly after next Power off-on. And I wrote A.jic again, the result was same, TDO fail. But I wrote another jic-file, call as "B.jic" here in after, then auto configuration has done and my program in Arria 10 ran correctly. After that, I write A.jic file again, then auto configuration has done and my program ran correctly. And after that A.jic file writing has been always fine. I have three boards, and I checked two boards ran correctly by this writing manner above, writing B.jic. And I still have one failed board, not writing B.jic. I extracted program data from EPCQ-L by Examine function via Active serial port, and I found each pof-files in three boards, two fine and one fail, were exact same. So I believe program file in EPCQ-L and EPCQ-L itself should be fine. It looks 10AX016C4 issue, but very strange symptom. Does anyone have any idea? Thanks, Tetsuya12 Replies
Hi Tetsuya,
Escalated to Nios section. Please post it to Nios. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation) - Altera_Forum
Hi Tzi Khang,
Thank you for your suggestion. I have posted this article to the Nos forum as thread below. https://alteraforum.com/forum/showthread.php?t=57075&p=232235#post232235 Best regards, Tetsuya
