8 years agoArria 10 auto configuration issue with EPCQ-L
Hi experts, I come across a serious issue on my Arria 10 board, using 10AX016C4. Flash memory is EPCQ-L256 When I wrote program using jic-file with USB Blaster 2, some jic-file, call as "A.ji...
8 years agoHi tetsuya,
I believe you stuck somewhere here, thus I lead you towards https://www.altera.com/en_us/pdfs/literature/an/an370.pdf (https://www.altera.com/en_us/pdfs/literature/an/an370.pdf) Direct refer pg9 is stating the condition for multiple configuration. I simplify the elaboration: It depends on data size, configuration device required, and note: The Quartus II Convert Programming File tool creates a .jic file based on the setting you set. Configuration will fail if the wrong configuration device type selected in the Convert Programming File tool. However, configuration will work if you have more configuration devices on your design compared to your settings in Convert Programming File tool. This shall solve your problem. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation)
