8 years agoArria 10 auto configuration issue with EPCQ-L
Hi experts, I come across a serious issue on my Arria 10 board, using 10AX016C4. Flash memory is EPCQ-L256 When I wrote program using jic-file with USB Blaster 2, some jic-file, call as "A.ji...
8 years agoHi Tzi Khang, Lim,
By the way, as I mentioned above, the both jic files were generated from same sof-file and it is used only "Convert Program Files" of programmer for building jic-file. And there are not so many options. Is it good enough to compare the setting of "Convert Program Files"? Regards, Tetsuya
