8 years agoArria 10 auto configuration issue with EPCQ-L
Hi experts, I come across a serious issue on my Arria 10 board, using 10AX016C4. Flash memory is EPCQ-L256 When I wrote program using jic-file with USB Blaster 2, some jic-file, call as "A.ji...
8 years agoHi tetsuya,
1. Are you sure A.jic and B.jic you generated all using the same settings likewise in picture? Including all tabs? 2. It seems like you go so far and started to compare both jic files using hex editor to get the difference without making sure all settings between A.jic and B.jic look perfectly same. 3. Please provide the settings you chosen before go next step asking latest question you posted. JTAG should not be unable to be programmed if you are in the correct settings. 4. Between, I have tried notepad++ which completely cannot decrypt, and notepad neo which able to see only first few lines info likewise you said, however, it is not possible to read encrypted binary data, so no point comparing in this method. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation)
