12 years agoarm-linux-gnueabihf-gcc command not found
Hey,guys, how to solve the problem which is "arm-linux-gnueabihf-gcc command not found" at the Embedded_Command_shell when I type "make" command? I follow the instruction in My_First_HPS.pdf to build...
12 years ago --- Quote Start --- Hey,guys, how to solve the problem which is "arm-linux-gnueabihf-gcc command not found" at the Embedded_Command_shell when I type "make" command? I follow the instruction in My_First_HPS.pdf to build the executable file but fail with this error!!! Quartus version I used is 13.0 . --- Quote End --- please provide the weblink for "My_First_HPS.pdf" or attached in this post.
