12 years agoarm-linux-gnueabihf-gcc command not found
Hey,guys, how to solve the problem which is "arm-linux-gnueabihf-gcc command not found" at the Embedded_Command_shell when I type "make" command? I follow the instruction in My_First_HPS.pdf to build...
12 years agoI'm glad you got your problem solved. However, it's good practice to write a short description of what the problem was and how it was solved. When other users google for the same problem they might find an actual solution to the problem.
