Arial10 VCCT_GXB and VCCR_GXB Voltage should be 1.03V for PCIe 3.0?
- 7 years ago
Hello ,
Answer to your first question : Yes , data rate in datasheet is for each late , here is the Intel Arria 10 transceiver phy guide: Section "Transceiver PHY Architecture Overview"
here is the link for your reference
Answer to your second questions , Yes , you can very well use as long as power consumption is not concern for your application. Keeping at 1.03 V also help to upgrade the data rate in future as per datasheet.
Thank you ,
Hello ,
Thank you ,
- xytech7 years ago
Contributor
Thanks, Sree. You answer really helps.
