xytech
Contributor
7 years agoArial10 VCCT_GXB and VCCR_GXB Voltage should be 1.03V for PCIe 3.0?
Hi there, we are using 10AX057H3F34E2SG transceivers for PCIE GEN3.0 x4 lanes for Chip-to-COMe Module(PC module on board) . As we know, PCIE 3.0 is max. 8GT/s, which is less than 10Gbps data rate m...
- 7 years ago
Hello ,
Answer to your first question : Yes , data rate in datasheet is for each late , here is the Intel Arria 10 transceiver phy guide: Section "Transceiver PHY Architecture Overview"
here is the link for your reference
Answer to your second questions , Yes , you can very well use as long as power consumption is not concern for your application. Keeping at 1.03 V also help to upgrade the data rate in future as per datasheet.
Thank you ,
xytech
Contributor
7 years agoup
