xytech's avatar
xytech
7 years ago
Arial10 Power-Up Calibration Clock Question
Hi, we are using ​10AX057H3F34E2SG for PCIe GEN3.0 x4 lanes, connected to a PC module by Board to Board connects.
I read on section 7.3 of UG-01143 (Arria 10 Transceiver PHY User Guide, page582) that user need to provide a CLOCK for proper transceiver for power-up calibration, and only Power-ON Calibration are allowed for PCIe..
Question1: Is this CLK refer to CLKUSR or dedicated XCVR REFCLK pin pairs, or both? As marked with red and blue lines in below picture. I guess both CLKUSR and XCVR clock should be provided to FPGA. But still need intel confirm.Question2: For section 7.3, what's the specific definition of "Programm" action in first sentence? Does it refer to Configuration, or Initialization, or both? Also, I'm confused that seems to be conflict between the FIRST and SECOND sentence for this paragraph. First sentence indicates that XCVR calibration start AFTER "programmed" , while second sentence indicates that calibration could continue DURING "Programming
", and may extend into user-mode.
How to understand this? I guess the seuqence should be Power on -->Configuration-->Initialization-->XCVR Calinration( user mode in parallel). Not sure......When EXACTLY the calibration begins? Is there timing diagrams on Intel docs?
Question3: To avoid the well-known “100 ms boot time requirement for PCIe”, We decide to power FPGA first, after detect the CONFIG_DONE signal be pulled high, then start PC, then the PCIe reference clock will be sent from PC to FPGA GXB banks.
However, this will be CONFLICT with UG-01143 section 3.2 , page381 note, which writes “To successfully complete the calibration process, the reference clocks driving the PLLs (ATX PLL, fPLL, CDR/CMU PLL) must be stable and free running at start of FPGA configuration”. Do you have any insight about how could we solve this conflict?
For now, we use ASx4 config scheme, and no likely to change it for other config schemes.
Thanks very much!
  • Hi @xytech​
    Calibration starts during configuration.
    No timing sequence, the time for calibration to complete vary by device.
    Based on experience, faster configuration time is needed if you are designing for open-system to meet the 100ms. For closed-system, you can adjust the PERST to allow more time.
    Hope this helps.
