17 years agoArggh! Error: Can't find port "ocp_enable" in OpenCore Plus entity "auk_ddr_hp_init".
Hi there I have a really annoying problem on Quartus 8.1 when compiling designs that feature SOPC with DDR Error: Can't find port "ocp_enable" in OpenCore Plus entity "auk_ddr_hp_init". -- Ope...
17 years ago@dine909 - Don't apologize - I saw you were using 7.2 from an earlier post. I didn't install it because the WEB site clearly showed a later version. Had I known files were missing, then it wouldn't have been nearly as bad. The learning curve is sharp enough - I didn't need the extra frustration to add to the slow start of simply running a demo app.
I'm moving along starting to put the foundations in for our application. Now it's not too bad, but I find many things annoying about Eclipse and more, the debugger. I wasn't thrilled with CodeWarrior which I just finished a project with, but now I see how much better a debugger it was, and yes, it too had several annoyances but several features that will be much harder to work productively without them in Ecliipse. Thanks!
