Are there any impacts to performance or functionality/temperature rating when operating the MAX 10 at high altitude (25,000+ ft)?
Intel has been studying the effects of SEUs on its device for many process generations and has built up extensive experience in both the reduction of soft-error rates through SEU-optimized physical layout and process technology, and in soft-error mitigation techniques. Intel introduced the industry's first automatic cyclical redundancy check (CRC) and removed the extra logic and complexity requirements common to other error checking solutions. Intel® device families are all tested for SEU behavior and performance using facilities such as Los Alamos Weapons Neutron Research (WNR) using standard test procedures defined by JEDEC's JESD-89 spec. To understand further of the SEU, you can refer to the link below:
For Max 10 SEU report generation, you can refer to the video clip below:
https://www.youtube.com/watch?v=eqcmuwGpGAI
Please be noted that per JESD89A, it is based on the altitude of 10,000 feet above New York City.
Thank you
Chia Ling
