17 years agoapplied counter at use verilog hdl in quartus II on board Cyclon II
I use Cyclon II board to applied Counter program by verilog hdl code in quartus II when compiler program successful ok Now My problem I want start counter up when Press push button from 0 untel ...
17 years ago --- Quote Start --- ok iwill remove ena module counter ( clk, reset, result, ena ); input clk; input reset; output [3:0] result; reg [3:0] result; always @(posedge clk or posedge reset) begin if (reset) result = 0; else result = result + 1; end endmodule now you know de2 board it's has 4 poshbutton I want press poshbutton just one time or only press button at firs count after that the count increase number from 0 to 15 between 0 and 1 for exam 50ns ok . I don't like press button all time. Are you anderstand me now? --- Quote End --- Hi, should the count stop at "15" and starting again after pressing the reset ? Kind regards GPK
