17 years agoapplied counter at use verilog hdl in quartus II on board Cyclon II
I use Cyclon II board to applied Counter program by verilog hdl code in quartus II when compiler program successful ok Now My problem I want start counter up when Press push button from 0 untel ...
17 years ago --- Quote Start --- ena is enable count I assined switch to do so in board. If you understand me How count increase without always press poshbotun I want generate clock itself. --- Quote End --- The easiest way to get rid of the botton is removing the ena signal in your design. By doing that, the counter will count up with every positive clock edge. Could you please describe more detailed what you would like to do with your design ? How are you generating the require clock ? Kind regards GPK
