19 years agoApparent Reset Glitch on Synchronous Reset
While running SW tests, at random times it looks like all my internal registers are getting cleared to their reset values. This is true for both registers and SOPC modules. Depending on the SW I ru...
19 years agoHi Stefan ,
In your design , is there any reset case like this one ? ------------------------------------------------------------------ library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity glitch is generic ( RESET_VAL : natural := 170; WIDTH : natural := 8 ); port ( areset : in std_logic; clk : in std_logic; ena : in std_logic; Q : out std_logic_vector(WIDTH-1 downto 0) ); end entity glitch; architecture behavioral of glitch is signal cnt : integer range 0 to RESET_VAL-1 := 0; begin process (areset, clk, cnt) begin if areset = '1' then cnt <= 0; elsif cnt = RESET_VAL-1 then cnt <= 0; elsif clk = '1' and clk 'event then if ena = '1' then cnt <= cnt + 1; end if; end if; end process; Q <= conv_std_logic_vector(cnt, WIDTH); end behavioral; ------------------------------------------------------------------ I have tried this before , I evaluated it in a MAX II Device EPM570T100C5 Everything works fine in TIMING simulation in Quartus II However when I downloaded the program to the CPLD (actually it is not only a counter design , a total of 570 LE) Then I checked the signal waveform on the scope I have found that the coutner part is reset to zero in an average of 19 rounds but it failed to reset (not returning to zero) at 20th round in an average The solution is : process (areset, clk, cnt) begin if areset = '1' then cnt <= 0; elsif clk = '1' and clk 'event then if ena = '1' then if cnt = RESET_VAL-1 then cnt <= 0; else cnt <= cnt + 1; end if; end if; end if; end process; I am not sure if this is your case , Hope it helps Cheuk
