8 years agoaoc compiler Error: Peak virtual memory: 496 megabytes
I try to compile my design. I issue the compile command as below
aoc device\opencl_cnn.cl -o bin\opencl_cnn.aocx --board a10gx -v But, there is an error message, what is the meaning? I need to change my pc settting(virtual memory)? aoc: First stage compilation completed successfully. Error: Peak virtual memory: 496 megabytes Error: Processing ended: Mon Oct 30 09:21:26 2017 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:00 Error: ip-generate FAILED. Refer to opencl_cnn/opencl_cnn.log for details. After enlarging the virtual memory, no Error: Peak virtual memory: 496 megabytes error message. But, there is another error message as below: The problem is about my pc hardware requirement not enough? aoc: First stage compilation completed successfully. Error: Compiler Error, not able to generate hardware Thanks, MattNo RepliesBe the first to reply
