18 years agoAnyone used the video sync generator in Quartus 7.2??
The reason I ask is that it is confusing me a lot. The documentation says that the RGB output has a variable width that is configurable via the 'data stream bit width' variable (if no one believes...
17 years ago --- Quote Start --- I had a response from Altera support, after kicking up a fuss, that there is indeed a bug with the IP block. I have also got a contact within Altera who sent me a modified .tcl script and an alternative vhdl block that will clock in 8 bits per 3 beats and output them in one 24 bit wide O/P. That saved me the effort! --- Quote End --- Can you share the code?I use the video sync generator in my design with DE2-35 and LTM, but the output is a massive noise,like TV.The same design is worked in NEEK, the VD HD DEN signal is fine, but nothing output in EP1C6Q240 or EP2C8Q208, I am frustrated in this.
