anyone explain the flash programming setting for arria 10, part number 10AX115S2F45I1SG,
- 5 years ago
Hi @APPU_appu,
Thank you for posting and sharing the finding in Intel community forum, hope this message find you well and apologies for the delayed in response.
Per understanding from the previous conversation, please do refer to the following steps here that will bring you through on generating the hex files.
Hope that helps to clarify.Best Wishes
BB
part number is : 10AX115S2F45I1SG and flash epcql1024
May I know which address do you start writing into the flash? If you are writing into address 0x0 of the flash then it will not work. You will need write to address 0x20 of the flash.
Do you generate with Little Endian or Big Endian? You can change the rpd endian through the Option setting.
- APPU_appu5 years ago
@JohnT_Intel
address : 0x20 of the flash and little endian used while generating .rpd file
