anyone explain the flash programming setting for arria 10, part number 10AX115S2F45I1SG,
- 5 years ago
Hi @APPU_appu,
Thank you for posting and sharing the finding in Intel community forum, hope this message find you well and apologies for the delayed in response.
Per understanding from the previous conversation, please do refer to the following steps here that will bring you through on generating the hex files.
Hope that helps to clarify.Best Wishes
BB
May I know what is the error observed? The reason is that the image is very blur.
Hii @JohnT_Intel @n_scott_pearson
Thanks for replying
1.Here the issue is how to generate .hex file (if i generate .hex file with the nios tool, while generating .jic file Quartus tool is telling like address overlap with 0x0000_00F0).
2. What should be the address for Nios IP and generic serial IP for reset vector.
3.what should be written in main.c (nios II SBT) to connect remote terminal
4. how to connect remote teminal our project
Thanks @JohnT_Intel
Below i attached my project arria 10 (part number : 10AX115S2F45I1SG and flash EPCQL1024)
