16 years agoAny ideas why this code isn't working
Backgroung, working with Terasic DE1 kit Trying to grab serial data from Copernicus Chip, interface http://www.sparkfun.com/datasheets/G...cus_Manual.pdf by default chip should give us $GPGGA onc...
16 years agoBy using Verilog part select expressions, most of your text collapses to a few lines, e.g.:
gpstream<=bitstreamin; Generally, it can't be seen, if your code uses an edge sensitive always block as required. So you may want to throw away the bitwise assignment garbage and show the overall structure, too.
