16 years agoAny idea why this SPI code didn't work?
Hi, i am a beginner in designing using VHDL. I need to construct interconnection between ADC(ADS7861 from Texas) and FPGA DE2 board. I have been told to use a SPI --- a serial to parallel SPi interface between ADC and FPGA. I have constructed the VHDL code for master(FPGA) and slave (ADC).
I understand that SPI only consists of 4 wires but my ADC having more than that. Therefore, i used Data_out( for MISO in slave), modeselect_A0 or convst (for MOSI in slave). The total cycle needed for conversion is 32cycles but i only obtain the data till 16 cycles as the A0(I use mode 2 which is( M0=0,M1=1,A0=1)==>CHA1). After 16 cycle the A0 =0 so it convert for CHA0,so i stop then. I put the CS always to low so that it is always ready to sent data. I hope that someone please help me in this case. Thank you in advanced master LIBRARY ieee; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; LIBRARY work; ENTITY ADC_MASTER IS PORT( serial_data_clock : IN STD_LOGIC; serial_convst : IN STD_LOGIC; serial_modeselect_A0 : IN STD_LOGIC; serial_slaveselect : IN STD_LOGIC; Data_in : IN STD_LOGIC_vector(15 downto 0) ); END ENTITY; ARCHITECTURE main OF ADC_MASTER IS shared variable data_register : BIT_VECTOR(15 downto 0); shared variable data_counter : integer range 0 to 15 := 0; BEGIN recv_data: PROCESS(serial_data_clock,serial_slaveselect) BEGIN if serial_slaveselect ='1' then data_counter := 0; else(serial_data_clock'event = '1' and serial_data_clock ='1') then if serial_convst = '1' and serial_modeselect_A0 = '1' then if data_counter < 15 then data_register(0) := to_stdlogicvector(Data_in); data_register := data_register sll 1; data_counter := data_counter +1; else data_register(0) := to_bit(Data_in); data_register := to_bit(data_register); end if; end if; end if; END PROCESS; PROCESS(data_register) BEGIN if serial_convst = '0' then data_counter := 0; data_register <=(other=>'0'); elsif rising_edge (data_register) and data_counter < 15 then data_counter <= data_counter + 1; if (counter>"000000000000010") then data_register(15 downto 1) <= data_register(14 downto 0); data_register(0) <= Data_in; end if; end if; END PROCESS; END main; slave LIBRARY ieee; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; LIBRARY work; ENTITY ADC_SLAVE_SPI IS PORT( serial_data_clock : IN STD_LOGIC; serial_convst : IN STD_LOGIC; serial_modeselect_A0 : IN STD_LOGIC; serial_slaveselect : IN STD_LOGIC; Data_out : OUT STD_LOGIC_vector(15 downto 0) ); END ENTITY; ARCHITECTURE main OF ADC_SLAVE_SPI IS shared variable data_register: STD_LOGIC_VECTOR(15 downto 0); shared variable data_counter : integer range 0 to 15 := 0; BEGIN PROCESS(serial_slaveselect) BEGIN if serial_convst = '0' then Dataout<="0000000000000000"; elsif serial_modeselect_A0='1' and rising_edge(serial_slaveselect) then Data_out<=data_register; end if; END PROCESS; PROCESS(serial_slaveselect,serial_data_clock) BEGIN if serial_slaveselect='0' then if rising_edge(serial_data_clock) then data_register<=data_register(15 downto 0); end if; end if; END PROCESS; END main;1 Reply
I stopped reading the post at the port definition, that shows only inputs. Can't work as a SPI master interface.
