any generic solution for usbblaster driver issue for all tool verison
Thank you contacting Intel community.
We are sorry for the inconveniences.
The drivers patch we have is not working for Quartus Prime Lite.
Here is a manual method that you can try:
Manual Method:
1 - Go to windows 10 settings and search for "advanced startup options"
2 - Under Advanced startup, hit "Restart now"
3 - After a moment, you'll get a "choose an option" screen - choose "Troubleshoot", then "Advanced options", then "Startup Settings"
4 - You'll get a screen telling you what you will be able to change and a single "Restart" button - press it.
5 - If your boot drive is BitLocker encrypted, you'll need to enter the recovery key (press return, enter the key in the text box then hit return again - it took me three goes to realize I had to hit return before I could enter they key !)
6 - You'll be given a menu of options, number 7 disables driver signature enforcement
7 - When the PC restarts, use Device manager to update the drivers - this time you'll get a warning about the signature, but they install fine.
8 - When you've finished, restart normally to re-enable signature enforcement
Aiman
- venkatasateesh4 years ago
Hi dear intel team,
what is this recovery key? where i will get recovery key
i am looking forward for your response
Thanks&Regards
sateesh
