17 years agoAND vs XOR gate
Im sorry if my post doesnt belong to here. Just a short question: Which one is larger in term of implementation? AND gate or XOR gate ? thanks
17 years agoIn an ASIC if I remember correctly the XOR gate will be larger transistor wise than an AND gate. Like Kaz said, ASICs don't use lookup tables to implement logic since they are not designed to be reprogrammed. When you program an FPGA one of the things you are doing is programming the lookup tables to implement your combinatorial logic. In an ASIC this logic are just static transistors which keeps the size and power down.
