17 years agoAND vs XOR gate
Im sorry if my post doesnt belong to here. Just a short question: Which one is larger in term of implementation? AND gate or XOR gate ? thanks
17 years agoHi,
ASIC design is different world from ours(the fpga). Though it is based on RTL usually. You will need to refer to their literature but it certainly does not use lut. Instead it is based on standard cells. Each vendor provides a library of these cells. The cells are designed at transistor level to directly implement some logical functions e.g. and,or,nand etc as well as registers/flips. The vendors are free to choose and design their lowest level functions in whatever way. The library or the user can combine these cells to produce higher level functions. Si, I believe, the answer depends on the cells you choose.
